Home > Forums > CD-adapco
multiphase or multicomponent.... That's the probl
Old   March 6, 2002, 09:49
Default multiphase or multicomponent.... That's the probl
july
My question is. If i treat only gas phases, what kind of difference it is between multicomponent or multiphase? Why a multicomponent analisys need a background fluid? I've two stream one of h2 and the the other of O2 each containing H20 (vapour)I want know the concentration of each specie... How can setup this kind of model... multiphase approach or multicomponent ? Thank's
Old   March 7, 2002, 03:27
Default Re: multiphase or multicomponent.... That's the pr
Daniel
Multiphase flow (in your case) means the fuel is in the liquid phase, if your H2 is injected liquid, you have to use this kind of model, otherwise, in case of an all-gaseous analysis you don't need that. Multicomponent flow means you are using gases with different properties. The background fluid is convenient since air is the background fluid almost everywhere in the physical world. For your problem - define Air for example as the background fluid (even if it's not really present in your case), define the properties of all species present, set the proper concentrations of all species at the inlets and solve.
Thread Tools
Trackbacks are On
Multiphase Multicomponent David FLUENT 2 January 19, 2004 06:04
Multiphase Multicomponent David Phoenics 0 January 19, 2004 01:50
Multiphase multicomponent system David CFX 0 January 15, 2004 21:59
Multiphase + Multicomponent Thitikorn FLUENT 5 March 21, 2002 04:38
Multiphase or Multicomponent Pandu Sattvika CFX 10 January 7, 2002 05:40
