Home > Forums > CD-adapco
Moderately porous media
Old   March 7, 2002, 09:33
Default Moderately porous media
Jing
According to the suggestion of the StarCD manual, I call the user subroutine SORMOM.f and solve the full momentum equations in order to simulate a moderately porous media.
I got the expected velocity value in the middle of the porous media. But the velocity at the inlet and the outlet of the porous media are smaller than the value in the middle. The flow field before and after the poros media has higher velocity again. I have hoped that I should get a gradually decreased velocity. Not like currently results: higher-lower-higher-lower-higher
Have some people had the same problem? Your opinions are appreciated.
Thanks!
Old   March 8, 2002, 15:03
Default Re: Moderately porous media
john
The pressure gradient is very different at the two sides of the porous-nonporous interface. With mometum source, this "discontinuity" in pressure gradient is not considered properly, resulting in the "decoupling" problem you described. If you use STAR's internal porous media treatment, the problem will not exist.
Old   March 11, 2002, 05:32
Jing
Thanks, john! Your opinions are always very helpful for me. In my calculation, alpha= 70000 and Beta = 0. Could I use the internal porous treatment of StarCD for the moderately porous media?
Old   March 11, 2002, 05:50
john
I think when you see noticeable decoupling, then the mometum source treatment is not no longer good. Of course, the Darcy's law only applies when the following condition is valid:
(ALPHA*U+BETA)*L/(density*U) >>1 where L and U are the characteristic length and velocity scales of the medium. It is also advisable to NOT use BETA=0. because ALPHA*U could go to zero in reverse flow, leading to numerical instability.
Old   March 12, 2002, 04:00
july
i'm not a great user of star cd but setiing beta = 0 leads to instability... refer to the methodology manual
Old   March 12, 2002, 09:25
ml
I once set beta=1*e-4 and alpha=~1000 and the run did converge and the result seems reasonable. So I would suggest you define beta as a very small value and alpha=70000, see it it works.
My point is although it is not recommended to set beta=0 which may lead instability, it doesn't hurt to have a try.
Old   March 13, 2002, 05:51
Jing
Thanks for all the suggestions! I will try the internal porous method of StarCD in my case.
Old   March 13, 2002, 07:58
Joern Beilke
You can try "switch 149" if you run into problems.
Old   April 8, 2002, 09:28
july
I'm interested also in porous media cause i'm working in Fuel Cell modelling. My question is: what kind of problem have you modelled? In my case i've a straight channel with a very thin porous layer above.
Thread Tools
Trackbacks are On
porous media in CFX X. Shen CFX 2 September 4, 2010 06:46
Free media&porous media.Big changes in properties. Isi Main CFD Forum 1 July 14, 2008 07:18
how to set porous media? may song Phoenics 4 August 18, 2002 07:05
Porous baffle and porous media Jan CD-adapco 0 June 8, 2002 09:23
Porous media James Hampson FLUENT 1 January 12, 2001 13:29
