Home > Forums > CD-adapco
Heat Transfer
Old   April 1, 2002, 11:11
Default Heat Transfer
Sharon
I am trying to achieve HTC at the internal surface of manifold. Can someone help me with the BC please. Manifold has a thickness of 2.5 mm. Look forward to hearing from you.
Thanks Sharon
Old   April 3, 2002, 14:29
Default Re: Heat Transfer
Achim
what ? achieve the internal htc ?
I presume you what to investigate the internel flow field, so the internal htc is part of your solution. I'm not quite sure of you intention but if I morph your question to what I think it could be a useful one, the answer is the following:
if you know the environment temperature and the external htc then fix the wall temperature and the thermal resistance R according to one-dimensional conduction in circular ducts as
R = 1/{Di/De*htc_e + 0.5*Di/cnd * ln(De/Di)}
Di,De = internal, external diameter; htc_e = external htc; cnd = conductivity of manifold;
if you know the external wall temperature then fix this instead of the environment temperature and ignore the convection term in the above eqation.
but if you still want to set the internal htc, then use modswf.
finally if your only problem is to get the htc, then be sure to checkbox the relevant variable to be written to your postfile and use getw htran or getw hcoef command.
regards
Thread Tools
Trackbacks are On
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 07:33
HEAT-TRANSFER & EXCHANGE HEAT MODEL Problems Jordi FLUENT 1 March 31, 2006 10:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
