crack at interface of hexahedron & tetrahedron mes
Old   April 1, 2002, 16:52
Default crack at interface of hexahedron & tetrahedron mes
KS
The geometry was meshed by using hexahedron meshes while a small part was meshed with tetrahedron meshes. At the interface of these two types of cells, cell faces match nicely. vmerge merged all multiple vertices. However there is a crack region all over the interface. I think this shouldn't be there. Anybody has any idea about this issue? Thanks in advance for any response.
KS
Old   April 1, 2002, 21:43
Default Re: crack at interface of hexahedron & tetrahedron
cjtune
I think you need some kinda coupling, either arbitrary or integral. I use ICEM-CFD for creating hybrid meshes and at the interfaces beween the hexa and tetras, ICEM always creates pyramid elements for 1-to-1 connectivity. 1-to-1 as in cell surface, not just vertices. Note that you need at least 2 tets to cover any one side of a hex (2 triangles = 1 square). I can't comment on Pro*AM as I haven't used it for anything other than trimmed cell meshes.
Old   April 2, 2002, 04:04
cjtune
You need a 1-to-1 match not only with the vertices but also with the surfaces. Since you can only cover on side of a hex (square) with two tets (triangles), I suggest you try arbitrary or integral coupling. If you want perfect matching, you need pyramids as intermediate cells between the hexs and the tets. I use ICEM-CFD for hybrid meshes and this is the way it matches hex and tet domains. Not sure about how Pro*AM handles hybrids meshes...
Old   April 2, 2002, 04:07
Default Sorry, internet connection lag... (n/t)
cjtune
Old   April 2, 2002, 13:35
steve
You need to add cpmatches at the hex/tet interface. If they match exactly (ie 2 triangles to each quad face) then you can you integral cpmatches. If not then you need the arbitraries.
[Technical] Second order tetrahedron mesh msrinath80 OpenFOAM Meshing & Mesh Conversion 2 November 21, 2008 13:41
hexahedron mesh for cfx Mihail CFX 1 April 14, 2008 09:19
found crack in prostar but no crack in CCM+ ?? Ingear Siemens 4 October 23, 2006 09:37
point inside a hexahedron gama Main CFD Forum 6 July 28, 2006 09:06
Neighbors of TETRAHEDRON in GAMBIT Amaresh Dalal FLUENT 0 August 18, 2004 23:07
