flow towards and from dead-end
Old   April 23, 2002, 07:23
Default flow towards and from dead-end
Bo Jensen
Hallo
I have made two simulations on the same geometry. The geometry is a T piece with one end of the top bar closed one diameter from the intersection. I have modeled flow so it enters either one way or the other through the T piece. I get the highst relative pressure in the dead-end in the case where flow is away from the T piece and not as I would expect when flow is towards the dead-end. Could andone give an reasonable explantion of this. (by relative pressure I mean the pressure seen in relation to the mean pressure on the outlet surface.
Regards
Bo
EXA dead ? CFD_user Main CFD Forum 2 February 1, 2005 22:56
Dead Leg zahid FLUENT 0 September 15, 2003 07:03
Is powerflow dead or still alive ? john Main CFD Forum 11 July 1, 2003 09:10
Why does the Fluent seem to be dead ... Knick FLUENT 5 January 22, 2003 19:42
Is CFD a dead end? Sebastien Perron Main CFD Forum 17 March 25, 2001 21:00
