April 17, 2002, 09:41 |
Convert from StarCD 3.10 to StarCD 3.15
Hellow! every peope!
I convert my case from StarCD 3.10 to StarCD 3.15. When I start a new calculation or a restart in the new version, I can not get a converged results any more. Before that, I can get the convergd results in the old version. My case concerns the moderatly porous media as well as some baffles in the solution domain. I convert the case just by execute the command "PROLINKL". I wonder if there are some conflicts between the two versions on these aspects. Or, if I should do more when I convert the case. Thanks for your help! |
April 17, 2002, 10:22 |
Re: Convert from StarCD 3.10 to StarCD 3.15
The under-relaxation parameter for pressure has increased from 0.2 to 0.3. Try setting it back to 0.2.
You should rewrite the geom and prob files and do a starlink (not a prolinkl) B. |
Display Modes | |
StarCD and HyperMesh | Joseph | Siemens | 3 | March 28, 2007 14:56 |
can not run starcd 3.15 in windows XP? | xhliu1 | Siemens | 2 | November 3, 2006 12:46 |
Fluent & StarCD | İbrahim Utku | FLUENT | 0 | March 28, 2006 08:14 |
Problem with Starcd V 3.22 and 3.24 | Amarjeet | Siemens | 2 | October 25, 2005 13:50 |
New to StarCD | Matt | Siemens | 2 | September 23, 2005 23:50 |
