Lift
Old   April 18, 2002, 15:48
Default Lift
Paul
Dear All,
I'm working in calculation of external aerodynamics of automotiobiles. The main problem i have is, that the drag is brilliant but the lift is very poor. Im using k epsilon model. Are there any basic things i have to take care about. The surfacemesh is fine enough and quality is good. 5 boundary layers are used.
Old   April 18, 2002, 22:20
Default Re: Lift
Joern Beilke
Run it transient.
Old   April 19, 2002, 18:54
Default Re: Lift
paul 2
Lift is probably the toughest aerodynamic coefficient to predict. Deciding what goes up and over and what goes down and under is not easy.
Make sure the y+ on the surface is within what k-e wants - 30 to 300??? And it would probably be better if the y+ was consistant over the entire surface of the vehicle. More cells between the bottom of the car/vehicle and the floor will also help.
Old   April 20, 2002, 07:17
Default Re: Lift
Paul
This is what i thought about too, Do you have any experiences about the time scales? What timestep is common for such problems?
Old   April 20, 2002, 07:22
Default Re: Lift
Paul
Do you have any experiences in using other turbulence models. I saw in Auto Technology Fluent is doing it with a Reynolds Stress Model. What do you think about that
Old   April 22, 2002, 06:52
Default Re: Lift
Holidays
Try the SST model of Menter or a k-omega model...
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
Lift and Drag Konstantinos Siemens 1 March 5, 2006 22:48
lift calculation shani FLUENT 1 January 28, 2005 03:35
lift coefficient nikita FLUENT 1 July 19, 2003 03:45
Lift co-efs F.P. mie FLUENT 8 December 13, 2000 11:09
