Physical properties of radicals for NOx modelling |
May 10, 2002, 09:13 |
I have trouble finding physical properties (for the file props.dbs) of radicals (O,H,OH) which I need to model in order to be able to get good predictions of NOx emissions. Has anybody experience with this and/or can suggest some good source for these properties?
The properties are namely density, Cp, molecular viscosity, thermal conductivity, heat and temperature of formation. Btw, the heats of formation of hydrocarbons included in the database surprisingly don't correspond with commonly available data. What's your suggestion? Thanks, Jirka. |
May 10, 2002, 13:38 |
Re: Physical properties of radicals for NOx modell
Try looking on the NIST website. You can get most of the data you need.
May 13, 2002, 03:30 |
Thanks, but I tried this one as well as CEA/NASA site, and the data published there is not complete.
Maybe if there's someone with personal experience of NOx modelling in Star..? |
May 13, 2002, 12:32 |
The properties of NOx you asked about have practically no influence on the fluid properties, since their concentrations in the fluid are very small. These properties are not used by STAR-CD since you define the scalars for these species as passive.
May 14, 2002, 04:08 |
Yes, thank you, Daniel, but my question applies to the situation when you use PPDF modelling, not local source. For the first approach you need the properties for proper calculation of NOx levels even though they are certainly not important for the flow solution.
May 19, 2002, 01:45 |
density - equation of state (ideal gas law) Cp, enthalpy, heat of formation - NIST WEBBOOK Viscosity, conductivity , binary diffusion coefficient - gas kinetic theory (statistical mech)
physical properties in material panel. | NEIL | FLUENT | 0 | April 26, 2007 14:30 |
physical properties of smoke | matt | FLUENT | 3 | December 19, 2006 03:20 |
physical properties used in CFD codes | Craig Branch | Main CFD Forum | 2 | September 28, 2004 03:35 |
Physical properties about "Air Ideal Gas" In CFX | Twiti | CFX | 2 | July 10, 2004 02:22 |
Variable physical properties of fluids/solids | rosco | FLUENT | 6 | May 11, 2003 16:10 |
