Home > Forums > CD-adapco
Viscosity and equation status
Old   June 11, 2002, 05:59
Default Viscosity and equation status
Mir
I have a turbolent flow with standard air, in Solution Control>Equation Behaviour>Primary variables Equation Status can I swhitch Viscosity in the fluid properties? If I don't swhitch it I have a solution, oterwise it's totally different. I defined constant viscosity , then where is the difference?
Old   June 11, 2002, 13:42
Default Re: Viscosity and equation status
john YL
If it's turbulent flow, then if you choose Thermophysics Models>Turbulence Models> select ON (choose a model) for example K-E/High Reynolds Number, then in your selected panel, the viscosity should be on automatically. If you switch off viscosity, you are running laminar flow.
Old   June 13, 2002, 08:24
Anton Lyaskin
All this happens because viscosity consists of two parts - molecular viscosity, wich is set constant in your case and so called "turbulent viscosity" wich is calculated from turbulence parameters (k and epsilon). Turning on viscosity in primary variables tells the code to calculate and account for turbulent viscosity.
Old   June 13, 2002, 13:39
Mir
Thanks. I solved this problem reading the Userguide, Commands and Methodology Manuals.
Thread Tools
Trackbacks are On
Path status in DPM BC UDF HS FLUENT 4 June 12, 2014 07:12
Explanation of status report of equation solution nico OpenFOAM Running, Solving & CFD 0 April 15, 2006 05:36
differential equation for turbulent viscosity mateus FLUENT 0 March 4, 2005 02:45
What is this status message David Baker CD-adapco 3 July 31, 2003 02:54
VOF status Paul Main CFD Forum 6 June 30, 2003 20:26
