-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Parallel run (http://www.cfd-online.com/Forums/cd-adapco/52945-parallel-run.html)
Bogdan June 24, 2002 08:28
Parallel run
How can i make this prohpc to work, when i'm trying to split the files for a parallel run it only split the geom file and nothing else.
Sven June 25, 2002 15:26
Re: Parallel run
You have to go through all steps (decompose, link, create directories (distributed data), copy data and start the case) in ProHPC.
steve June 26, 2002 10:31
Re: Parallel run
Unless you are doing a restart, the geom file is the only file that needs to be split. All the others are copied without change to the right locations.
