July 20, 2002, 10:25 |
sublayer
I am meshing a manifold with prostar. I want to put on a sublayer after regular hex blocks mesh is completed. Can anyone tell me how to do it. Thanks Guang
July 21, 2002, 14:26 |
Re: sublayer
Try to understand the following script:
vc3d 0 1 20 0 1 20 0 1 20 ctab 2 flui 8 ctab 10 shell 4 ctab 11 shell 5 cset news flui live surf create cset news shell cset subs gran ,,, 0.99 1.01 cdel cset cset news shell ctype 10 cmod cset *get xx mxve cset news type 10 vset news cset vgen 2 xx vset cgen 2 xx cset cset invert cset subs type 10 ctype 11 cmod cset ctype 2 *set zz xx * -1 vcex 1 zz cset ,,, norm -0.02 cset news flui view 1 1 1 plty ehid cplo |
July 25, 2002, 14:30 |
Re: sublayer
Hi Joern, Thank you for advice. I fully understood the procedure (cgen a lager with dt=0 and then vcex reverse inward to keep surface shape while creating a layer with specific layer). However the version 3.15 does not support vcex with -value, which is a regression of prostar as far as I concern. Could you give any suggestion around. Thank you again Guang Ai
July 25, 2002, 17:56 |
Re: sublayer
I've tested it with 3.15 and it worked.
other way: use proam to generate a sublayer first (shrink the original surface). the algorithm there is much more robust than the vcex command. my way would be to use gridpro. |
July 26, 2002, 08:31 |
Re: sublayer
Thank you Joern. I will try it in proam. It seems something wrong here in SGI/Unix setting if it is not the fault of version3.15.
Viscous sublayer thickness | Bo Busk Jensen | Main CFD Forum | 4 | April 13, 2011 01:25 |
viscous sublayer in turbuelt flows | student | Main CFD Forum | 0 | June 22, 2007 05:05 |
High aspect ratio in viscous sublayer? | Marius | Main CFD Forum | 0 | December 22, 2005 08:15 |
Sublayer in Pro-am | michael | Siemens | 1 | June 9, 2004 08:53 |
abt k-ep and viscous sublayer | AMV | Main CFD Forum | 0 | December 3, 2002 09:05 |
