Exponential Cell Spacing
How can I reduce the number of cells on any direction (I or J) in which, the spacing of the cells is not linear (ie I have used the ratio command).Is it possible to progressively decrease the number of cells from 24 to 12 between tho adjustment patches.
Thanks. |
Re: Exponential Cell Spacing
you can manipulate cell number outside prostar and then 'cread' in. check the format of '*.cel' and you will find the way. Good luck.
