create new surface
Old   July 28, 2002, 04:31
Default create new surface
subhash
Dear Sir, I am doing meshing for intake manifold using proam I want to generate the new surface for geometry.While diong the create new surface it is destoring the surface at the inlet and outlet side of geometry.I tried differant cell length from 4 to o.05 then also same thing haaping. Can anybody help me to solve this prpblem Thank you Subhash
Old   July 29, 2002, 08:53
Default Re: create new surface
guang ai
you have to fix the original surface first.
Old   July 30, 2002, 03:53
AK Balasubramanian
Dear Subhash,
You can use the custom mesh, with suitably refined in those regions.
Also make sure that you have generated Edge Lines and Points before making the surface.
Alternaletly generate the surface mesh using PATRAN and import the surface mesh.
Regards, AK Balasubramanian
How to create a circular surface? Jen FLUENT 7 December 7, 2020 13:09
Iso-surface: How do you create and display? Lukasz Mosakowski FLUENT 5 August 15, 2011 15:08
Help ! Create surface for sliding mesh. YH Tan FLUENT 0 October 5, 2008 04:21
How to create a hole on the surface Radhika Siemens 4 December 8, 2006 05:16
Create Thin Surface in Mesh2CAD Jeniffer CFX 0 November 4, 2003 17:24
