Home > Forums > CD-adapco
Steady State Natural Convection problem with PISO
Old   August 7, 2002, 01:00
Default Steady State Natural Convection problem with PISO
jerry
hi , all I tried Steady State Natural Convection problem with PISO algorithms. But this warning occurs.. Who do know this warning, solution?
*** WARNING #043 *** MINIMUM RESIDUAL AT THE END, RETURNING NON-CONVERGED SOLUTION
RESU = 5.79205E-03 RESV = 4.46443E-03 RESW = 4.42205E-03 RESP = 5.27473E-01
REST = 1.21827E-04
*** WARNING #013 *** MAXIMUM SPECIFIED CORRECTOR STAGES 20 REACHED BEFORE CONVERGENCE CRITERION IS SATISFIED.
<<<<CONTINUITY EQUATION NOT CONVERGED>>>>
Old   August 7, 2002, 08:34
Default Re: Steady State Natural Convection problem with P
john YL
This may indicate that you have reached the steady state solution and PISO can not reduce the residuals any further?
Old   August 7, 2002, 20:30
jerry
Thanks Mr.john YL for your reply.... I want to know whether the warning affects my solution, and know the way to remove the warning.
Please post response.
Thank you!!!!!!!
Old   August 12, 2002, 06:47
marco
Hallo Jerry!
I think your solution is NOT converged. You can try increasing the maximum number of PISO corrector stages to a higher number. And you should link star in double precision (that's always advisable with natural convection problems).
If you can't get a converged solution this way, then you should try a transient aproach, as most natural convection problems are not stationary.
Thread Tools
Trackbacks are On
Convergence problem using simpleFoam steady state vvqf OpenFOAM Running, Solving & CFD 12 May 18, 2011 07:51
transient problem run in steady state luigi FLUENT 4 March 13, 2008 07:54
steady state PISO problem denizen CD-adapco 0 December 20, 2006 03:55
Psedo-time steps in Steady state problem Blackdraft FLUENT 0 July 14, 2002 05:23
Piso for steady state Andrea CD-adapco 11 April 19, 2002 07:33
