Home > Forums > CD-adapco
Adjacent cell number
Old   October 8, 2002, 10:25
Default Adjacent cell number
Jing
HI!
I need to know the cell number of the cell adjacent to a special cell. Could you be so kind to tell me by which parameter or by which way I can get it?
Thank you!
Old   October 9, 2002, 04:50
Default Re: Adjacent cell number
Marc
You get the command by unsing a common block ( /DCO5/ ). It is named LQ(I,IC), which wirtes back the neighbour of STAR Cell IC through face I I: 1: Bottom, 2: Top, 3:South 4:North 5:West 6:East
Hope that helps
Old   October 11, 2002, 04:36
Jing
Thank you for the reply! But I can not find the common block (/DC05) as well as the parameter LQ(I,IC). Could you be so kind to tell me where I can find them and in which user subroutine they are inputted in?
Thanks again!
Jing
Old   October 11, 2002, 05:04
Marc
You can implement the common block in all subroutines (whereever you need them), but it is already done in posdat.f, so there you can use the LQ(I,IC).
Marc Poppner
PS: Be careful the common block is DCO5, not DC05. (an O instead of a zero)
Old   October 18, 2002, 10:59
Jiaying Xu
Does the array LQ(I,IC) also record the neighbouring relations if I use unstructured mesh? I am also interested in the issue for my user coding.
Thanks for your further hints.
Jiaying
Old   October 21, 2002, 06:29
marc
I think so, you have a more detailed discription of the cell faces in the manual (depending on the sequence of its vertices), which can be applied on all cell afaik. if you have collapsed cells, the "lost" face will be ignored.
greez Marc
Thread Tools
Trackbacks are On
Retrieving boundary patch values adjacent to a given cell brooksmoses OpenFOAM Post-Processing 2 December 8, 2008 11:00
In reply to: "only one adjacent cell thread." Krystian FLUENT 0 August 27, 2008 20:39
adjacent cell zones Louisa FLUENT 4 August 31, 2007 06:49
how to connect faces(only one adjacent cell thread BC FLUENT 8 July 13, 2005 16:07
two adjacent cell zones. Thejasvi FLUENT 3 November 26, 2001 09:35
