Countour(filled) and vector plot about symm axis
Old   October 11, 2002, 00:23
Default Countour(filled) and vector plot about symm axis
sachin pande
Hi
I am solving one symmetric problem... I want to present that problem as half contour(filled) and another half as vector.
what i have to do get both plot.
Thanks in advance
regards
sachin
Old   October 11, 2002, 07:35
Default Re: Countour(filled) and vector plot about symm ax
stefan
When you have something like an orthogonal view on a section cut, then you can try this:
Make the symmetry plane the center of your plot (using cent command), e.g. when the symmetry plane is the xy-plane (z=0) then set the z-coordinate of the cent-command to 0. Use dist command for the right distance.
Plot the first half (contours).
over on
view reve
Plot the second half (vectors).
over off
vector plot ehsan Main CFD Forum 2 January 7, 2008 02:50
vector plot cfxdude CFX 3 June 17, 2007 16:38
How to Plot the Alphabet of Countour Line Wendy Tjia Siemens 0 August 31, 2005 04:14
Filled Temperature Plot Wim FLUENT 2 May 9, 2004 15:26
Software for vector plot Gert-Jan van der Gulik Main CFD Forum 3 October 27, 1999 07:28
