changes in V3.15
Old   October 11, 2002, 04:52
Default changes in V3.15
Nicola
Hello all,
I'm studying a laminar steady flow in a quite complex geometry. My problem is: after changing to the new version of star, I can't reach convergence anymore. Does anyone know about changes of default values? Or something different?
Thanks, Nicola
Old   October 11, 2002, 07:05
Default Re: changes in V3.15
stefan
Look at the release notes:
The default value for the pressure under-relaxation has been changed from 0.2 to 0.3.
The default residual normalization factor has been changed to what used to be the 'alternative' factor in v3.10.
etc...
Old   October 11, 2002, 07:34
James
I think the whole normalisation method has changed. Not only a factor. In my opinion the former switch 105 is now used by default.
Old   October 11, 2002, 07:41
stefan
This is what I meant. I just copied the text from the release notes (look there for further details.)
Old   October 11, 2002, 08:05
Joern Beilke
Also the pressure gradient calculation was changed. You can switch back to the old (least square) method using "switch 60 on"
Old   October 11, 2002, 09:11
Nicola
thanks for your answers, but where can I find the release notes?
Old   October 15, 2002, 01:12
stefan
Use Help menu in prostar or look in $STARDIR/man/rnotes.
