Home > Forums > CD-adapco
Plot wall boundaries & drops
Old   October 24, 2002, 02:45
Default Plot wall boundaries & drops
Ossi
Hi, I wonder what is the way of plotting walls and droplets at the same time ? I have no glm version available. The walls could be shaded to give them more 3-D look.
Old   October 24, 2002, 02:55
Default Re: Plot wall boundaries & drops
Lars Ola Liavåg
Hello Ossi,
You can always perform a wall plot with the "interior" or "clipped hidden" plot type (you need surface shells to use this). Then you can either use pldisp,droplets,on with that plot, or you can use the overlay command and plot the shells and droplets separately.
A problem that I haven't been able to solve is that you cannot easily achieve a true "hidden effect" where at the same time, droplets that are behind a surface close to you are hidden and droplets that are in front of a more distant surface are visible. Either the droplets are plotted on top of the shells, or vice versa. Anybody know a solution to this?
Lars Ola
Old   November 6, 2002, 05:04
Ossi
How do I obtain the surface shells ?
Old   November 6, 2002, 06:36
Lars Ola Liavåg
You can for instance use live surf, or you can just make a cell & wall bnd plot (creates surface shells automatically). To visualise the surface shells, you just collect the shells in the cset and use wplot. This can also give nice images in the clipped hidden mode. Setting the plot type to interior allows you to plot directly the surfaces defined by the vset. Check the plty command in PROSTAR help for more help.
regs.
Lars Ola
Old   November 12, 2002, 15:04
massimo
Excuse me,i wont to plot the heat wall flux (from pst file), how can find or recognise the shell that i must plot; my model have many different group of cell.
Old   November 14, 2002, 05:44
Nicola
Hi Massimo,
you can check the number NR of the interesting cell set in the cell table, then activate it via cset,newset,type,NR and then choose your data and plot it with cplot.
Old   November 14, 2002, 15:32
massimo
I'll try to do it. Thank you.
Old   November 18, 2002, 10:35
massimo
Another question: I want to save the cell wall data that are displayed but when I save it, in a file, there are the values of all cells. How can I get it? Bye
Thread Tools
Trackbacks are On
interpolation on faces and wall boundaries ca Main CFD Forum 0 September 2, 2008 12:42
Wall Burning Along Inflated Boundaries John CFX 0 July 31, 2008 00:26
Unwanted Wall Boundaries for 3D geometries Cappy FLUENT 1 July 27, 2006 01:39
particle plot with boundaries ema CD-adapco 0 September 12, 2005 05:31
How i can create a wall with out boundaries??? STK FLUENT 1 July 7, 2004 13:20
