turbulence convergence
Old   November 19, 2002, 03:47
Default turbulence convergence
irfan
Hello.
After getting the solution, I am facing a difficulty in judging that the particular set of input turbulence parameters (example; Dissipation length scale & Turbulence intensity in standard K E modal), being selected are correct. For this, should I check the residuals of turbulence only or do I need to check something else.
I will appreciate your guidance in this regard
IRFAN
Old   November 19, 2002, 04:38
Default Re: turbulence convergence
Ossi
If you are only considering turbulent quantities from the convergence point of view, I think the only good way to say if your solution is converged is to run the case with two different convergence criteria and see if the result changes. If not, then you should be ok.
convergence issue with turbulence mar Siemens 5 February 2, 2015 02:42
Laminar Turbulence convergence Paul S. FLUENT 3 October 29, 2008 09:19
Turbulence model convergence problem Andrew CFX 7 August 17, 2008 19:35
Convergence problems with SSG turbulence model Ram CFX 1 June 19, 2006 10:08
residual convergence with turbulence modeling eddybreakup Main CFD Forum 0 June 10, 2004 16:17
