What variable(s) for facet area on the boundary? |
November 20, 2002, 11:08 |
Hello, STAR users,
I need to sum up the volumatic flow flux through the outlet boundary, but anyone can tell me what variable(s) or array(s) stand for the facet area on the boundary? Which common block should I quote into bcdefo.f? I am using an all-tetrahedral mesh. I believe STAR should have stored the info into some variable(s) and I don't need to code the area(s) in my user subroutines. Many thanks for your help, Jiaying |
November 23, 2002, 02:33 |
Re: What variable(s) for facet area on the boundar
under the post menu, you can stor the facet area into a register and store the facet varialbls into another register then then multiply this two register and set the result into the third register
sum up the values in the 1st and last two registers respectively, and execute divide , you can get the average value |
Display Modes | |
how to calculate the area of a boundary in UDF? | peter | FLUENT | 2 | May 31, 2021 21:54 |
Average Facet, Surface Vertex or Area-Weighted | Emmanuel | FLUENT | 3 | March 27, 2020 11:55 |
Facet, Area and Mass Average in Fluent | Tushar | FLUENT | 0 | February 6, 2009 00:55 |
Facet, Area and Mass Average in Fluent | Tushar | Main CFD Forum | 0 | February 4, 2009 05:37 |
cell surface area in boundary.. | Chiar | FLUENT | 0 | March 7, 2007 04:53 |
