-   Siemens (https://www.cfd-online.com/Forums/siemens/)
-   -   to kill a job with files written (https://www.cfd-online.com/Forums/siemens/53097-kill-job-files-written.html)
Ossi November 27, 2002 04:43
Hi, I would like to stop my steady state run so that all the files will be written out before it stops. Is there an option with the kill-command so that all the files are written before the run stops ??
Anton Lyaskin November 27, 2002 05:21
Re: to kill a job with files written
Hi! To stop Star-CD run just create a file named ABORT (in caps!) in the case directory. If you're under UNIX/Linux you can use command touch ABORT.
guang ai November 27, 2002 08:50
Hi Anton, could you please drop several words about what is the case directory. I will be very grateful.
Anton Lyaskin November 29, 2002 05:19
Hi! The case directory is the directory from which you run your job, where all your case files are located (.mod, .geom, .prob, etc.)
