-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Droplets breakup (http://www.cfd-online.com/Forums/cd-adapco/53117-droplets-breakup.html)
Julie Polyakh December 10, 2002 15:09
Droplets breakup
Does anybody have successful experience modeling droplets breakup with STAR-CD?
Regards,
Julie
Ossi December 11, 2002 03:16
Re: Droplets breakup
It depends on how you define "successful"...
Julie Polyakh December 11, 2002 05:58
I want the computations to agree with experiment. (Now you will ask how do I define "agree"?)
Ossi December 11, 2002 06:25
We have simuleted drops in diesel engines as well as in constant volume bombs. The constant volume bomb computations have been compared with experiments done in the same conditions (spray penetration, drop SMD, spray width and spray shape).
Julie Polyakh December 11, 2002 14:08
Have you calculated drops breakup? I don't see that it works.
In general, I have problems with drops trajectory. It seems like the drag coefficient is too small.
Another question is cell dimensions. Can you give me specific example of cell dimensions from your model?
Ossi December 12, 2002 04:28
I assume you are doing transient simulations because you are trying to breakup droplets. I have not observed problems in drop drag. In constant volume bomb simulations I am typically using cylindrical grid and the cell size is roughly 1mm in every direction near the nozzle. Gradually the cell size is getting bigger when moving away from the nozzle location.
Julie Polyakh December 12, 2002 05:02
Hi Ossi,
I am performing steady-state simulation. There are nothing said about break-up model apliciability with simulation types. Moveover, they use the Reitz breakup in Tutorial 2.3 in steady-state calculation.
Can you explain the meaning of Droplet Trajectory Max File Size(MB) and of Maximum Tracking Time values, please? How one determinates their values and how do they influence the solution?
Thank you,
Julie
Ossi December 12, 2002 05:21
I think one cannot use the droplet collision model for steady-state runs, sorry about that.
Max file size is the max allowed file size of the case.trk file, and max tracking time will ensure that if a drop for some reason will go to a never-ending loop, it will not be tracked more than the specified time.
Julie Polyakh December 12, 2002 05:36
I was talking about droplets breakup (not droplets collision) model.
If I set max .trk file size smaller than it really is, what happens then?
