Ground Effect & Turbolence Model
Old   December 10, 2002, 06:13
Default Ground Effect & Turbolence Model
Stefano
I have to study the Ground effect. Anyone knows which one is the best model for this kind of problems? - ke hi reynolds - ke low re - ke RNG - two layers Thanks
Old   December 11, 2002, 05:25
Default Re: Ground Effect & Turbolence Model
Nicola
Hi Stefano,
what do you mean with "Ground effect"? The turbulence models are depending on Reynolds-number, wall roughness, the grid, etc. Read about them in the methodology-manual.
Old   December 11, 2002, 06:09
Stefano
Nicola, i have a profile moving near a wall so i have zone at low Re number but also zone ( throw profile and wall ) at high velocity and high viscous effect. IN the past i used ke Hi Re number, now i'm using RNG model but the coefficients i found ( lift and drag) are different from ke ( expecially lift ), and the y+ values are often really high. I refine the mesh more times but y+ changes any time i change the value of U inlet velocity Have i to try 2-layers model?
Old   December 17, 2002, 06:59
marco
Hallo Stefano!
For your problem the 2-Layer model should be the best choice. Anyway you need a very fine mesh: more then 10 cells should be contained in the boundary Layer! That means Y+ < 1.
Moreover, as the y+ values are depending on the flow velocity, you need feiner meshes for higher velocities.
Regards
Marco
wing in ground effect meenakshi FLUENT 1 July 12, 2008 13:29
CFD in Ground Effect CFD Newbee FLUENT 1 January 14, 2008 15:27
Ground effect d bull CFX 1 April 12, 2007 08:39
Wing on ground effect John Tong FLUENT 0 September 4, 2006 23:31
Wing in Ground Effect mondal Main CFD Forum 2 June 28, 2006 06:12
