[Sponsors] | |||||
Yesterday i started having problems when running 3.15A under windows, when star is linking and creating the executable i get the message #link error: file not found - formula.obj first it was formula.obj so i tried moving it into the working directory then another and another eventually i had to move a whole bunch of files because star couldnt find them even when they were where they were supposed to be. I have checked my environmentals and they seem fine but it just wont run unless i move all these files. I was playing around with my registry but didnt touch any star-cd stuff but that is when the problem started. any idea what i might have done and how to fix it without copying loads of files everytime i want to run a sim?
in all likelyhood, your LIB variable is not pointing at the necessary STAR-CD library paths
nope all the lib environmentals are fine, any other ideas?
you should open a command prompt and do a set > setout and use a text editor to look at the setout file...I'm pretty sure you will find that your LIB variable is not set right...which is why it can't find formula.obj...probably you have LIB set in both the user environment variable section and the system environment variable section...watch out...windows will use the user variable setting to override the system variable setting.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problems in personal library compilation | shrina | OpenFOAM | 3 | February 23, 2009 11:12 |
| Specifying probe locations in controlDict using dictionary file | vincent | OpenFOAM Bugs | 3 | December 31, 2008 04:25 |
| UDF compilation problems | MateuszZb | FLUENT | 4 | October 20, 2008 02:46 |
| PROBLEMS WITH THE COMPILATION | oscar_j | OpenFOAM Running, Solving & CFD | 6 | July 18, 2007 21:41 |
| Compilation error with C++ header file | Jack Martinez | FLUENT | 3 | June 16, 2007 09:27 |
