Droplets not found in the domain
Old   February 5, 2003, 14:13
Default Droplets not found in the domain
Julie Polyakh
I have copied my model with droplets injection into the new folder and created new geometry (in the same axes limits). Each time I try to run a new analysis, appears the following warning: "Warning #019: 50 new parcels have been injected and only 0 is found in the domain".
Is there any way to fix the problem (excluding entering all the parcels from the beginning)?
Thank you in advance,
Julie
Old   February 6, 2003, 01:24
Default Re: Droplets not found in the domain
Stefan
I had the same messages several times, but each time I had some parameter set badly, e.g. the coordinate system for the injector was outside my domain, the units my mesh was in differed to the units the coord.system was created. I guess this message can also appear, when you put the injector at some symmetry or generally at boundary planes.
injection not found in domain error San FLUENT 3 March 17, 2009 22:24
Is there any functionality of OpenFOAM to solve multiblock domain without merging the domain swlee OpenFOAM Running, Solving & CFD 4 January 23, 2008 12:18
DPMprobelm-Injection not found in domain Sally FLUENT 0 December 13, 2005 22:19
DPM - droplets John FLUENT 4 August 21, 2005 00:12
3-D droplets ? Ossi Siemens 1 September 16, 2002 08:02
