February 5, 2003, 15:13 |
Droplets not found in the domain
I have copied my model with droplets injection into the new folder and created new geometry (in the same axes limits). Each time I try to run a new analysis, appears the following warning: "Warning #019: 50 new parcels have been injected and only 0 is found in the domain". Is there any way to fix the problem (excluding entering all the parcels from the beginning)? Thank you in advance, Julie |
February 6, 2003, 02:24 |
Re: Droplets not found in the domain
I had the same messages several times, but each time I had some parameter set badly, e.g. the coordinate system for the injector was outside my domain, the units my mesh was in differed to the units the coord.system was created. I guess this message can also appear, when you put the injector at some symmetry or generally at boundary planes.
Display Modes | |
injection not found in domain error | San | FLUENT | 3 | March 17, 2009 23:24 |
Is there any functionality of OpenFOAM to solve multiblock domain without merging the domain | swlee | OpenFOAM Running, Solving & CFD | 4 | January 23, 2008 13:18 |
DPMprobelm-Injection not found in domain | Sally | FLUENT | 0 | December 13, 2005 23:19 |
DPM - droplets | John | FLUENT | 4 | August 21, 2005 01:12 |
3-D droplets ? | Ossi | Siemens | 1 | September 16, 2002 09:02 |
