-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   WALL FUNCTION (http://www.cfd-online.com/Forums/cd-adapco/53192-wall-function.html)
tomosada February 14, 2003 07:29
WALL FUNCTION
1. How can I change the y+ of wall function ?? should i modify the subroutine "modswf.f" ?? If yes, how do i modify it ??
2. Did any body have used two-layer , where can i found the tutorial of the mode ??
Thank you for answer me!!
cjtune February 14, 2003 11:48
Re: WALL FUNCTION
I can't help on Q#1 but for Q#2, you have to turn on and choose one two-layer model in the 'turbulence models' tab, and turn on the 'Two-layer' option to 'Active' for the walls you want to use the model on. You can leave the other walls as normal (Two Layer = inactive) to use the 'regular' wall-function models on them to save time on calculations (eg. on areas of less interest).
