Negative densities at the start of a run
Old   February 21, 2003, 09:09
Default Negative densities at the start of a run
nandu
I am trying to model the supersonic flow between two finite width wedges. The model has approx 250000 elements. I am attempting to run it as an inviscid calculation with an upwind scheme. The solver fails within the first three steps citing 'negative densities found in more than 100 cells as the error'. how can this be rectified, any help in this matter is greatly appreciated.
cheers nandu
Old   February 21, 2003, 11:17
Default Re: Negative densities at the start of a run
cjtune
Try pseudo-transient runs. Adjust time step to taste. Also, try using double-precision. Worked for me.
Old   April 20, 2003, 22:48
azmir
Same problem... for my transient moving mesh case. I've tried: 1) changing the time step to be one order to order of magnitude smaller but didn't work. 2) using double precision but didn't work 3) changing all relaxation factors (everything not just pressure) but didn't work 4) all above with 2-3 different values as trial and error and still didn't work. 5) looking into mesh quality possibilities now... don't know yet.
Appreciate if someone with experience could give some tips here. Thanks.
Old   May 13, 2003, 16:18
Dave
I've had this problem quite often. From my expirence (I'm a fairly new user) mesh quality is the cause. I've only come across this when using PROAM to mesh.
negative densities john Siemens 0 March 19, 2008 06:32
Negative Densities shyam Siemens 2 May 8, 2005 06:17
negative densities. Mihir Siemens 4 December 9, 2002 21:04
negative densities Sabatini Siemens 4 January 31, 2002 08:06
negative densities Fabrizio Grieco Siemens 4 October 30, 2000 01:47
