Home > Forums > CD-adapco
Segmentation error
Old   March 4, 2003, 12:38
Default Segmentation error
Ulf
I have serious problem with the subroutine posdat (on a single job). I do some averaging for droplet variables in posdat. This routine has worked perfect until I changed configuration (80000 cells to 700000 cells) and suddenly I got segmentation error (crash) at iteration 1. The subroutine is not even activated at this stage. I have been forced to not include this routine in my computations, but I really need this. I would appreciate any help. Regards Ulf
Old   March 5, 2003, 15:29
Default Re: Segmentation error
steve
Are you dimensioning any arrays to 700000? If so are they simply dimensioned or are they in a common block? Fortran puts the memory in different places (stack vs heap vs who knows where it goes) depending upon how you define the array and sometimes you just need to move it to a different storage location.
Old   March 6, 2003, 03:24
Ulf
Hi steve, thanks for your response. My arrays are simply dimensioned, e.g. DIMENSION SQRD(NCMAX), CUBD(NCMAX). This is also what I believe, causes the problems. But I don't know how to fix it.
Old   March 6, 2003, 10:45
steve
Ulf, Try this
COMMON/ULFSCOMMON/SQRD(NCMAX),CUBD(NCMAX)
Instead of the dimension statement
Steve
Old   March 6, 2003, 12:11
Ulf
Hi steve, Thank you very much for the tip. It worked perfectly. Regards, Ulf
Old   March 11, 2003, 09:15
John
Hi Ulf and Steve, I see you are using posdat routine with Lagrangian. I currently have a problem running this on Linux. The case runs fine on SGI. Are you running on Linux too? John.
Old   March 11, 2003, 11:04
Ulf
Yes, I am running Linux.
Old   March 11, 2003, 13:29
John
Ulf/Steve, Could it be then, that Linux doesn't like the dimension statement causing it to segmentation fault? Ulf, have your tried your case on an SGI platform? If so, did it work? John.
Old   March 12, 2003, 03:40
Ulf
Hi John, I have not tried my job on a workstation. We have retired almost all our old workstations. Have you tried the tip steve gave me. /Ulf
Old   March 12, 2003, 05:25
John
Hi Ulf, I will try something like that. My dimension statements are actually in an include file which is referenced by other subroutines, so a straight substitution here will incur a "duplicate common statement" error. However, I will try a test.... Cheers, John.
Old   March 17, 2003, 10:11
  #11
steve
John, I can tell you absolutely that there is a limit on how big you can make a dimension statement when the array is not in common. A non-common dimensioned array goes on to stack which is usually limited compared to datasize or vmemoryuse. You should be able to construct you include files to have only 1 reference to a given common block.
Steve
Old   March 18, 2003, 11:43
  #12
John
Cheers Steve, On the case as we speak....
Thread Tools
Trackbacks are On
Segmentation error in tutorials mic CD-adapco 1 March 27, 2007 07:33
segmentation Fault/error rajesh CD-adapco 2 April 20, 2006 14:17
SEGMENTATION VIOLATION ERROR Cliff FLUENT 1 April 3, 2006 05:48
Segmentation Error Leo FLUENT 3 November 7, 2005 09:02
Segmentation Violation error anindya FLUENT 0 March 21, 2005 03:52
