Home > Forums > CD-adapco
BCDEFW and attached fluid cells
Old   March 14, 2003, 12:35
Default BCDEFW and attached fluid cells
Joern Beilke
How is it possible to get the Star or Prostar cell number of the fluid cell, which is attached to the boundary number "IBP" in the subroutine bcdefw.f ?
Old   March 16, 2003, 01:02
Default Re: BCDEFW and attached fluid cells
cjtune
Hi Joern,
Maybe this snippet of code from Adapco-Online could help:
do 220 ib=1,nbp23
ip=lx(ib)/7
indx=mod(lx(ib),7)
ibnd=lq(indx,ip)
ibndp=iblmap(-ibnd) 220 continue
Given a certain IB (IBP if passed thru IBLMAP; here it's ibndp), you can get IP with the help of the COMMON LX(IB).
Old   March 17, 2003, 04:51
Joern Beilke
I had this type of coding in mind when I started but it is much easier:
IF(IREG.EQ.2) THEN
WRITE(*,*) ' BCDEFW called for boundary ' , IBP ,
WRITE(*,*) ' BCDEFW called for Prostar CELL ' , IP ,
WRITE(*,*) ' BCDEFW called for Star CELL ' , IPSTAR ,
ENDIF
IP and IPSTAR are already available in the subroutine.
Old   July 8, 2003, 18:24
ed
This doesn't work for baffles. IBP is always zero if you are on "side 2" of the baffle The only way round I could find was to write a Prostar subroutine to output a table (using graph registers) of fluid cell and boundary numbers. This table can then be read into BCDEFW and used to find the real IBP number from the IP number by lookup, when the IBP in the subroutine returns zero.
If anyone else has seen this problem or has other solutions I would be interested to know.
Thread Tools
Trackbacks are On
Documentation of class primitiveMesh attached jaswi OpenFOAM Running, Solving & CFD 0 November 4, 2008 03:02
coupling solid and fluid cells?? kcg CD-adapco 4 March 13, 2007 10:39
Grap Fluid Cells Just On One Side Of A Baffle Tommy CD-adapco 0 May 7, 2006 07:49
Shell cells to Fluid cells Mahbub CD-adapco 1 October 20, 2003 15:21
flying object with a ribbon attached Dong Main CFD Forum 2 November 5, 1999 18:37
