April 1, 2003, 05:49 |
Resisdual
Hello, I have a problem with residual. I cannot display the residual, how can I get it? I have some files: .rsi, .rpo, .erd; which of them I must use? Which procedure I must use? Thank you in advance. Bye
April 1, 2003, 10:57 |
Re: Resisdual
The infomation you want is in the *.rsi file. Using prostar you should do
Graph > load grapha data > load STAR residuals + m... - load data - graph data |
April 2, 2003, 10:58 |
Re: Resisdual
You can do the same from StarGUIde: Analysis Praparation/Running->Run history of previous analysis->Plot Residuals
April 4, 2003, 05:43 |
Re: Resisdual
Thank you for your help. I have another question for you: When I do "plot to file", the star-cd create a new file .plot, but I cannot display it. Which program I must use for display the file .plot? Can I change the format of this file? Thank you in advance. Bye
April 4, 2003, 06:41 |
.plot File
Use plot-xm to display it on a X window. Use plot-gif to convert it to a gif-bitmap.
Greetings, Marc |
April 4, 2003, 06:43 |
Re: Resisdual
It depences on the computer system. If you use workstation, please use plot-xm(x). There are some other software can be used for show plot depending on your system.
April 4, 2003, 11:49 |
Re: Resisdual
Thank you for your help. I'm using the star-cd with win2000, which program can I use for display the file .plot? Bye
April 4, 2003, 15:44 |
Re: Resisdual
In the Star Launcher, choose plot-xm from the Neutral Plot Utilities menu
April 5, 2003, 07:19 |
Re: Resisdual
Thank you. I have another problem. I would like to track the "particle tracks" with the starguide but I find a problem: infact the particle tracks that I display, hide my model also when they are hiden from my model. How can I hide the particle tracks that are hide from my model? (for example: a wall hide a particle tracks when it trought back the wall). Thank you in advance. Bye
April 7, 2003, 00:58 |
Re: Resisdual
I think you can try converting your particle tracks into shell tubes. It is described at www.adapco-online.com/drpost/drpost5.html
