Home > Forums > CD-adapco
Combustion model in Diesel Engines
Old   April 7, 2003, 11:26
Default Combustion model in Diesel Engines
roadracer
Hi everybody
I have to simulate combustion in a diesel engine. On Star manual I can read that the Laminar and turbulent characteristic time model, that is a variation of the Magnussen model, is the recommended model for this kind of simulation. Has anyone used it? Why should it perform better that the PPDF model?
Old   May 13, 2003, 10:05
Default Re: Combustion model in Diesel Engines
franz
Diesel combustions doesn't work like a premixed SI-engine combustion. Due to the coexistent appearance of liquid fuel entrainment, mixture formation, ignition and combustion the whole combustion process is seen as mixing controlled. Combustion can only occour if air (=O2) and fuel vapour can come together. The speed of this "comming together" is proportional to the combustion rate because the chemical kinetic oxidation of the fuel with O2 is much faster then the mixing of the species. So the Magnussen model does account for the speed of this mixing process. The LATCT model additionaly does account for special effects in the near wall and spray regions.
Hope this helps, Franz
Thread Tools
Trackbacks are On
Fuel Modelling in Diesel Engines, what's truth Jo CD-adapco 0 August 18, 2004 13:47
simulation of combustion in engines mechighel farid Phoenics 9 May 12, 2002 10:58
Question on Diesel Engines Adrin Gharakhani Main CFD Forum 8 April 10, 2000 11:38
Radiation in diesel engines Chrys Correa Main CFD Forum 1 April 21, 1999 11:36
internal combustion engines with FLUENT Elizabet Main CFD Forum 1 April 14, 1999 13:10
