Couples usage in engine moving mesh
Old   May 15, 2003, 04:12
Default Couples usage in engine moving mesh
Alfred Herman
I have a IC Engine 3D moving mesh. Valve port and valve mesh structures are different, which forces me to use arbitrarycouples between these meshes. But I get a lot of warnings as *** WARNING #007 *** SETTING T AT CELL ***** FROM -2.795E+02 TO 0.01*TREF FOR DENSITY CALCULATION
and all the cell numbers indicated are some of those near the couple boundary. After 2 or 3 time steps, the solution shows negative densities. PS: The analysis ran successfully when I used perfectly merged identical valve and port mesh structures. Any clarification is appreciated.
Regards,
Alfred Herman
mesh engine for several software jecil Main CFD Forum 8 January 18, 2012 04:27
Moving Reference frame - UDF - Moving mesh modisa FLUENT 0 April 18, 2008 13:31
Need help to mesh Wankel engine Sam Main CFD Forum 3 October 4, 2007 20:33
CFD on a simple moving engine shreen Main CFD Forum 3 December 7, 2005 12:07
define moving mesh for engine step by step homan FLUENT 0 October 26, 2005 03:27
