May 21, 2003, 12:52 |
Multi Phase option problem....
Hi StarCD experts! I'm trying to run an analysis using the multi phase treatment on "Lagrangian Multi-phase". I have already solved my geometry (which is on Transient) and now I'm trying to put some Droplets.. When I restarting the analysis and I'm receiving a very "wierd" message:
" *** GEOMETRICAL CALCULATIONS STARTED *** GEOMETRICAL CALCULATIONS COMPLETED *** ERROR #244 *** MULTI-PHASE OPTION CHOSEN: INADEQUATE PARAMETER NCMAXV or/and NCTMXC IN parm.inc " I have already tried to correct the value in the prosize file with no luck... Can anyone suggest something? |
May 22, 2003, 07:53 |
Re: Multi Phase option problem....
Could be a prostar bug or could be caused by your not writing geometry file after turning on droplet. The solution is very simple: just edit parm.inc and put NCMAXV = NCMAX, NBMAXV=NBMAX, NBTMXC=NBMAX, NCTMAXC=NCTMAX and use starlink again.
Problem about multi-phase analysis (Urgent) | Prof. Lau (PolyU) | CFX | 2 | February 9, 2007 17:59 |
A strange problem when doing multi-phase flow | Yun Kang | CFX | 0 | September 28, 2006 09:26 |
Phase change with granular option. | MP | FLUENT | 0 | February 2, 2003 21:15 |
heat transfer problem in multi-phase flow | verypuzzled | CFX | 1 | October 3, 2001 11:16 |
Multi-phase | cehuang | FLUENT | 2 | October 1, 2001 15:25 |
