how to generate postscript file?
Old   May 22, 2003, 16:52
Default how to generate postscript file?
leo
I can generate .gif, but when I try to generate ps1 level, the program blow out.
And how to generate black and white picture? Thanks.
Old   May 22, 2003, 18:05
Default Re: how to generate postscript file?
Joern Beilke
term ,, file rast repl term ,,
plots to a file called "case.plot" or to the file:
nfile "otherfile.plot"
on the command line type >plot
choose "ps" and go on
the plot program asks you for color or bw
Old   May 27, 2003, 12:11
leo
When I go to the step "choose "ps" and go on" It does not work. Do you know any tutorial talking about this. Thanks.
Old   May 27, 2003, 13:03
Joern Beilke
user guide chapter 19 -- "Hard Copy Production"
It would be very helpful if you describe the "does not work" a bit more precisely. What did you try exactly and what did not work?
Old   May 27, 2003, 16:50
leo
Thanks.
I can generate some .plot file, but I don't know how to open it. Is the .plot file a graph file?
Old   May 27, 2003, 17:12
Joern Beilke
there exists the program "plot" to convert the .plot file to other formats. so exit prostar start the program "plot" from the command line and answer the questions.
the .plot file is also called "neutral plot file".
Old   May 27, 2003, 23:38
Lars Ola Liavåg
Leo,
The plot facility will fail if you haven't closed the case.plot file first. Whenever you're finished printing to it, write close casename.plot in PROSTAR. That makes the file "complete", and you can use it with e.g. plot-ps or open it in the animation module.
Regs.
Lars Ola
Postscript Problems John@ FLUENT 3 April 20, 2009 20:59
Buggy postscript output from CFX mcirri CFX 6 September 9, 2008 09:31
Generate chemkin appropriate file for a reaction ilati FLUENT 0 March 3, 2007 03:22
how can I generate new exe file in star-cd David Baker Siemens 10 September 6, 2003 00:18
How to generate a postscript file or a tif file? Ming-Jyh Chern Siemens 4 June 5, 2001 13:07
