Discretization scheme: whih one is good in my case
Old   June 3, 2003, 14:53
Default Discretization scheme: whih one is good in my case
Julie Polyakh
The case I work on includes droplets injection and evaporation, gas combustion, conjugate heat transfer and so on. Results obtained with UD scheme do not completely agree with experimental data (calculated maximum velocity is much greater). I tried to set MARS scheme for all variables, but now the conjugate heat transfer residual doesn't converge.
Looking forward for any help.
Julie
Old   June 4, 2003, 02:37
Default Re: Discretization scheme: whih one is good in my
Ossi
You should always use second order accurate schemes for at least velocity (momemtum). Otherwise your soution is basically rubbish. Of cource, second order accuracy for other variables too, if possible. Sometimes the convergence may be so poor that UD or some blended scheme is needed for e.g. turbulence. On the other hand, under-relaxation normally helps. In case you have steady state case, you may want to also try with the SMPISO pressure correction algorithm.
Old   June 5, 2003, 11:41
michael
MARS is a good choice. You may leave UD on k-epsilon. Try double precision to get converged solution for conjugate heat transfer residual.
Old   June 24, 2003, 20:27
skipio
Arguably if one has convergence problems one can start with ud on all variables and cd on density. Then after convergence is achieved restart with MARS on all variables. And of course probably use much lower under relazation than the default ones.
QUICK-Discretization Scheme Fonzie CFX 12 July 27, 2019 06:40
Time discretization scheme cfd Main CFD Forum 0 September 10, 2007 05:05
New discretization scheme arkangel OpenFOAM Running, Solving & CFD 2 June 7, 2007 20:41
VOF Discretization Scheme soy FLUENT 1 June 26, 2006 06:46
MARS discretization scheme raymond Siemens 3 February 1, 2002 05:33
