RNG turbulent model
Old   June 5, 2003, 12:59
Default RNG turbulent model
Julie Polyakh
Running my case with k-e\high Re turbulence model I do obtain convergence, but results show bad agreement with experiment (in particular velocity is much higer than in experiment). With RNG turbulence model my calculation diverges after 38-th iteration. Does this model require any special settings? If anybody has faced the similar problem please share your experience.
Regards,
Julie
Old   June 5, 2003, 13:24
Default Re: RNG turbulent model
allan
Difficult to say without knowing what type of modelling you're doing. I've had quite a bit of success with the ke-quadratic turbulence model in highly swirling flows.
allan
K-E vs RNG Turbulent MOdel CK FLOW-3D 6 January 11, 2009 03:17
Turbulent Model simon CFX 3 December 18, 2008 16:35
Which turbulent model should be used? erick CFX 5 July 17, 2007 04:53
Turbulent model & NS new one Main CFD Forum 3 November 13, 2002 07:59
turbulent model yong FLUENT 5 June 6, 2002 09:41
