-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   HELP: moving grid (http://www.cfd-online.com/Forums/cd-adapco/53340-help-moving-grid.html)
Sunlight007 June 5, 2003 17:11
HELP: moving grid
Hello, as a newbie i have several issues due to moving grid: 1) i have a very simple TRANSIENT case: 2) mesh is a cube and its vertices to be accelerated in NEWXYZ in x direction only CODE IN NEWXYZ
integer I J
real cons1 slope Vo Vx
cons=0.1
Vo=0.1
slope=cons1*Vo
Vx = Vo + slope*ITER CC---- accelarate in x direction
DO 10 I=1,NDMAXU
VCORN(1,I)=VCORN(1,I) + 0.1*TIME 10 CONTINUE
RETURN
END 3) through inlet a constant velocity, outlet default i have NOT attached (is this needed for my issue?) 3) i do not want to use EVENT module for starters 4) i give timestep command 4) i give per command PREVIEW and MOVING GRID: rcons 4 1 mvgrid on no event 5) i then save star.mdl, geom and prob files 6) in another window starlink, user subroutine yes, star
7)at post processing: iter 1 for vertices shows with VLIST ALL and iter 10 shows same values for vertex coordinates
getc all shows different values for velocity though. PLEASE HELP asap Greetings
