Moving mesh problem
Old   June 9, 2003, 08:42
Default Moving mesh problem
Jan Majer
I'd like to ask following question. I have generated a simple mesh block and I want to remove the first cell layer.
The first layer disappears, but the length of the neighbouring (remaining) cell layer grows twice. (When removing another cell layers, the problem reappears). Defining new coord. system with reoriented x-axis and then using it in command eddir doesn't help.
How can I fix it?
Thanks in advance.
Jan
Old   June 9, 2003, 10:18
Default Pictures of mesh
Jan Majer
picture of the original mesh: web.quick.cz/jan-majer/e00.jpg
picture of the changed mesh: web.quick.cz/jan-majer/e0.jpg
Old   June 10, 2003, 04:19
Default Re: Pictures of mesh
Anton Lyaskin
When deleting the cell layer you have first to change it's thickness to zero by moving vertices. It's look like you move your vertices in wrong direction - you have to move "external" vertices towards "internal"
Problem with moving mesh Sully FLUENT 7 September 11, 2008 00:38
Moving Mesh Problem Rashad FLUENT 0 August 28, 2006 04:31
moving mesh problem eos Siemens 4 January 27, 2006 20:42
moving mesh problem walid Siemens 6 April 1, 2005 17:31
Moving Mesh PROBLEM Arnab Siemens 10 October 30, 2004 02:10
