Restart with ProHPC
Old   June 9, 2003, 10:37
Default Restart with ProHPC
Julie Polyakh
Does anybody know how to restart a case with ProHPC?
Regards,
Julie
Old   June 9, 2003, 17:17
Default Re: Restart with ProHPC
TomK
Basically it is done the same as a restart with star. From the prostar gui guide select restart and save your problem file. Then, if you are restarting from an HPC run, just use the HPC gui to write files again. If you are starting from a single processor, in the HPC gui there is a section that allows you to split your .pst file for each processor. Note that the .pst file must be there even if you are doing a transient, because that is where your restart data is. If you are doing a transient, if you leave the .pstt file on the node, it will append to it. This could end up causing a file too large to be read with some versions of UNIX and LINUX.
After re-reading this, I am sure that I have made it clear as mud. If you have a specific question I can try to address it. Actually, though, like almost everything, it is a pretty easy process once you have done it the first time.
Good luck, TomK
Restart selim CFX 1 August 21, 2007 14:43
Restart furkan Siemens 3 February 14, 2006 16:57
Restart Orit Friedman Main CFD Forum 1 December 29, 2005 14:41
Urgent: Help on ProHPC Sachin S Deshmukh Siemens 5 August 3, 2004 07:24
restart Jane Siemens 2 March 26, 2004 02:33
