-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Covert Star-CD model to FLUENT (http://www.cfd-online.com/Forums/cd-adapco/53346-covert-star-cd-model-fluent.html)
Lam June 9, 2003 14:22
Hi. I am a CFD beginner who will model turbulent flow using FLUENT from existing Star-CD model. Can I convert the Star-CD model directly and run the simulation in FLUENT package? Is there any functions or methods to do that? Or it is something not related completely between these two package? If you have any information or idea, please let me know. I appreciate your opinions. Thanks.
Nameer Salman June 10, 2003 13:22
Re: Covert Star-CD model to FLUENT
yes, you could do that, you have to create domain file within prostar, then read in the domain file within ICEMCFD, and write out the .msh file to fluent from ICEMCFD. One thing that the above process is not direct, and you have to have ICEMCFD.
Paal June 11, 2003 02:47
In the lower end of the NavCentre(StarGuide), there is a folder called export. In this folder you can export grid in various formats. Most codes, probably also FLUENT, can read the NASTRAN format. Note you will only get the grid, not the boundary conditions, thermo-physical set-up and so on (So you will have to redefine this.)
Best of luck,
Paal
Joern Beilke June 11, 2003 02:48
It is easy as long as you dont have couples and trimmed celles.
Put shells with a unique cell type on every boundary region and export all in Nastran format.
Read the file into fluent (not GAMBIT !!!) and thats it.
Lam June 12, 2003 05:43
Is that means I just can convert mesh from Star-CD to FLUENT and I have to redo the solver and postprocessing parts in FLUENT? Thanks for your opinions.
Lam
steve June 13, 2003 10:49
Why would anyone ruin a perfectly good STAR model by running it in Fluent? The best you could hope for, if you are lucky, is an answer that is at least as good as STAR's (I suppose it is possible that I may be just a little biased).
The answer is - you do have to redo the set up, boundary condition values and post-processing to move to fluent or any other CFD program. This assumes that you actually can move the mesh since Fluent does not support as wide a variety of cell shapes as STAR does.
skipio June 24, 2003 20:21
By the way if you are exporting nastran or patran or cgns from starcd to fluent 6 it will work on linux or unix but not on win2k or winXP because Fluent 6 under windows seems to have a bug. This is valid untill about March 2003 and i haven't got a clue if there was a patch for this problem.
