How to get volume flow rate of a section?
My case is incompressible flow. I get the result by 2 ways.
1. I divided the model into two parts. After finish calculation, I read Mass Flux and put one part in a new cset then use post-> flux sum-> zone. 2. Read velocity and density. Use 'spoint curs' to select the section. Use 'intergrat cset' to get A*VN. Can somebody tell me what's the difference between these two method? The answers are different. Thank you very much. |
Re: How to get volume flow rate of a section?
They were probably different most likely because the location for "spoint curs" was different from your previous "zone." Try to control (write down) the spoint and snorm.
