Xwindows config
Old   June 12, 2003, 08:51
Default Xwindows config
Joel
Im running 3.15a on windows 2000 with sco xvision and my fond and things are all too big, any idea how to shrink them so that i can see what i am typing in instead of having to scroll all over the place?
Old   June 12, 2003, 23:52
Default Re: Xwindows config
CJ Tune
Check your Vision/Fonts folder and see if there's a '75Dpi' folder. If not, copy it from another XVision installation or reinstall XVision to get that smaller font size. It seems that sometimes the installation screws up and forgets to install that font size.
Old   June 13, 2003, 13:24
kevin
actually the xvision installer seems mildly brain damaged and will not install the 75dpi fonts if you choose the "typical" installation option...you need to select the "custom" installation option and then manually select the 75dpi fonts...the star-cd installation notes specifically instruct you to use the custom installation option for xvision if you install it manually.
Old   June 25, 2003, 05:22
Joel
i always find it funny that the main problem it seems with any engineering package (CAD, CFD, FEA) is never the package itself it is always the anoying little programmes that it requires to run around it (Xwindows and licence managers), these are the things that without fail break down and without fail take ages to fix because there is no logical explanation for them going tits up!!
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 09:37
CFD system config hari Main CFD Forum 1 November 12, 2007 09:02
how to config mpich1.2.4 in linux? andrew Main CFD Forum 0 December 24, 2002 07:21
