[Sponsors] | |||||
I want to change the reference pressure value from 1.0e+05 Pa to 0 Pa when I run a model,in the "monitoring and reference data" I tried to change the reference pressure value into 0 Pa,but when I typed the "apply" buton,I found the reference pressure data value always to return to 1.0e+05 Pa.
So,I want to know whether I can change the reference pressure value,if possible,how can I do? Thank you very much for your help! Lee |
This is probably a design erro - but as a fix, you can use a very small non-zero value such as 1.e-05
The thing is, the reference pressure value needs to be input as absolute pressure and if you set it to 0, you basically specify perfect vacuum; hardly a condition where the Navier-Stokes equations apply anymore... Perhaps CD have put a limit on purpose?
Regs, Lars Ola |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Reference pressure | Fernando Herrera | Main CFD Forum | 0 | August 21, 2008 11:41 |
| Reference Pressure | shashank | CD-adapco | 0 | April 5, 2007 15:48 |
| Reference Pressure | Prabodh V.K. | CD-adapco | 2 | December 24, 2003 01:30 |
| Reference Pressure | Danard | CFX | 2 | November 12, 2002 14:11 |
| reference pressure | Martin Nilsson | FLUENT | 2 | December 15, 2001 17:16 |
