Mysterious cells
Old   July 9, 2003, 12:35
Default Mysterious cells
Julie Polyakh
How could it be that a cset counts more cells that I can see?!
Multi-block meshing specialists please help!
Julie
Old   July 9, 2003, 13:41
Default Re: Mysterious cells
allan
perhaps you have double cells:
check,all,,dblc,news
for double cells and put them in a set, then:
cdel cset
will delete the double cells
allan
Old   July 10, 2003, 01:50
Julie Polyakh
Hi Allan,
I've tryed that. No effect. There are no double cells in the model.
Thanks anyway
Old   July 10, 2003, 14:13
Thomas
chech, if you have cells with zero or negative volume. try wire all plot.
Old   July 10, 2003, 14:32
Julie Polyakh
Hi Thomas,
I've just checked: there are no cells with zero or negative volume.
Thanks,
Julie
Old   July 10, 2003, 15:35
Not_even_close
1.Try chec cset,,face,news vset,news,cset cdis,on,vert cplot
2.or Try cset,dele,ccrs (just deselect the cells you can see) vset,news,cset cdis,on,vert cplot
Old   July 11, 2003, 05:23
allan
you may have cells that occupy the same space with different vertex numbers. Try:
cset all vset news cset vmer vset check,all,,dblc,news cdel cset
allan
How can I get the VOF value of specified cells Rui Siemens 2 February 2, 2007 03:20
Could you please help me about the cells liugx212 OpenFOAM Running, Solving & CFD 3 February 27, 2006 05:04
cells less than one Andrew Garrard FLUENT 6 January 27, 2005 05:15
Shell cells to Fluid cells Mahbub Siemens 1 October 20, 2003 15:21
UDF: neighbour cells, upwind cells Dmitriy Makarov FLUENT 0 February 18, 2001 13:53
