Global & Local axes
Old   August 3, 2003, 00:08
Default Global & Local axes
azmir
Hello! If I have a geometry not built according to default global axis but have all the BCs defined according to a new local axis, can the computation be run according to the local axis instead of the default global axis? (e.g. when refining cells and computing the u,v,w momenta in equation behavior-primary variables)? Thanks.
p/s: how about having a Star-Cd conference or training seminar in Bali or Lombok next year anyone? Can CD-adapco organize something like it?
Old   August 4, 2003, 20:51
Default Re: Global & Local axes
cjtune
Hello Azmir,
Actually everything you build is already based on the global coordinate system. If you need to view your vectors based on some local coord. system, you can try using the REFR command (GUIde>Post-processing>Load Data>Coord System).
CD-Adapco usually holds their user group meetings in the states, europe, and Japan. You can easily join in any one of them, more so if you wish to present something. You should try asking them directly.
axes Arj CFX 2 March 19, 2009 06:27
Global vs local residual ceyrows OpenFOAM Running, Solving & CFD 0 April 3, 2008 12:24
chansfer of axes mao FLUENT 0 August 30, 2006 20:36
Global and local variables Astrid CFX 8 April 16, 2002 00:52
Two rotating axes ? Michael Palm Main CFD Forum 1 September 1, 1999 07:59
