CL Front and CL Rear
Old   July 28, 2003, 22:11
Default CL Front and CL Rear
therry henry
hello, everyone... Anybody know how to define the CLF(lift front) and CLR (rear) by using StarCd... Normally, starcd gave the overall body fo the lift coeeficient.
I really appreciate if anybody can reply me problem..
thank u.. best regard
therry henry...
Old   July 30, 2003, 10:50
Default Re: CL Front and CL Rear
cjtune
I think the command ACOEF works only with a current selected set of wall shells... so if you only selected the 'front' of your model then you'll get the force coefficient for just that part. Repeat for the wall shells of the 'rear'.
Old   July 31, 2003, 23:36
therry henry
hay cjtune... thank you for your feedback..is there any simple way to devide the car body.., by using COG location maybe.. .. Where is the limit for the CLfront and CLrear? thank you.. buddy
regards
Old   August 1, 2003, 03:30
cjtune
Divide at center of gravity? To determine which halve is 'front' and which 'rear'? No idea for cars. With aerofoils it's easy since your have the chord line.
Perhaps where you want to get the CL depends on your area of interest. Say if you want to optimise the slope of the rear windscreen to reduce drag, you might do just as good to just plot out the CL only for that portion.
Cp values for F3 rear wing for a 4th year thesis Joe Bryant FLUENT 4 June 10, 2010 23:40
Rain on car rear windscreens Nic Main CFD Forum 2 February 19, 2004 06:49
Front Tracking and VOF Seeker01 FLUENT 2 February 6, 2003 22:52
Help needed - lift coefficient on front/rear axle Jan Jagrik FLUENT 0 September 21, 2000 10:21
Rear facing NACA ducts abn Main CFD Forum 0 January 15, 2000 22:19
