Home > Forums > CD-adapco
hpc with absoft 7.5
Old   August 4, 2003, 11:13
Default hpc with absoft 7.5
Marcio
Is it possible to compile a hpc run with absoft 7.5 instead of 7.0?
Old   August 4, 2003, 13:17
Default Re: hpc with absoft 7.5
TomK
I don't know about 7.5, but we use 8.0.
Old   August 4, 2003, 20:53
cjtune
If you have problems with Absoft, try checking the website for patches to download. I had problems running 8.0 on Mandrake 9.1 recently but it's OK now.
Old   August 5, 2003, 13:32
allan
I sucessfully ran star hpc with v7.5 of the compiler and mandrake v 8.2
allan
Old   August 5, 2003, 13:35
allan
allan.
Old   August 5, 2003, 13:38
allan
what version of xmotif were you using? I've had problems with absoft v7.5 and mandrake 9.1
cheers
allan
Old   August 5, 2003, 17:30
Joern Beilke
You have to install the 2.1 version of the motif libs. It is no problem if both libs are installed at the same time.
For use with suse 8.2 I had to apply the latest patches to the 7.0 compiler and it works.
Old   August 6, 2003, 03:16
Marcio
Thank you for your replies,
I work with SuSe 8.0 Kernel 4-18-64 SMP and Fortran 7.5. and it is not possible to link an executable. I always receive a message about undefined references.
Joern,
could you please tell where I can find the patch for the compiler and the version 2.1 of the motif libs ??
Old   August 6, 2003, 04:10
cjtune
It's v2.2.1 of openMotif, as mentioned by Joern below. But without, it would only show as graphical glitches on your GUI (if it doesn't crash first) but not problems linking the executable. Check the Absoft website to see if you can patch it or upgrade for free to 8.0.
Old   August 6, 2003, 04:16
Joern Beilke
You can get the Absoft patches from
ftp://ftp.absoft.com/pub/linux/profortran7.0
or
ftp://ftp.absoft.com/pub/linux/profortran7.5
I put the openmotif on my homepage:
http://www.beilke-cfd.de/openmotif-2.1.30-8.i386.rpm
You have to run
rpm -i --force openmotif-2.1.30-8.i386.rpm
Old   August 7, 2003, 13:10
  #11
4xF
1) SuSE 8.0 comes already along with the openmotif libraries v2.1.30-MLI4. Check first if you have installed it (call YaST2 -> Install/Remove Software). Unless it is already installed, you do not need to install any supplementary rpm. If need to perform a prolinkl or a pmovlink, in which case you will need to install additional package call openmotif-devel (to install, check again in YaST2 -> Install/Remove Software)
2) Which kind of error message do you get? Which kind of object or libraries are missing?
Old   August 7, 2003, 13:52
  #12
Joern Beilke
suse 8.2 comes with openmotif 2.2 and prostar requires 2.1. Thats why one has to install the 2.1 in addition to the already installed 2.2.
Old   August 10, 2003, 05:23
  #13
4xF
I thought Marcio was working with SuSE 8.0, not with 8.2 (see Reply from Aug. 6). In the case you have SuSE 8.2, you need to install the "old" openmotif package with rpm -i --force --nodeps, as stated previously.
Thread Tools
Trackbacks are On
absoft fortran 9 linux murash-v CD-adapco 5 August 22, 2007 04:44
Absoft F90 compiler for Star-CD 3.26 marcus CD-adapco 0 April 24, 2006 11:39
Star-CD v.3.22 and Absoft compiler Alex CD-adapco 1 November 21, 2004 05:44
Absoft Pro Fortran 7.5 in Fluent 4.5 Thitikorn FLUENT 0 July 5, 2002 06:41
Absoft environmentals joel CD-adapco 2 June 21, 2002 11:12
