Read Star-CD V2.2 in V3.10
Old   August 11, 2003, 07:08
Default Read Star-CD V2.2 in V3.10
Jos
Hi all cfd friends,
I am a begineer of Star-CD who want to convert some old star-CD files (version 2.2 in IRIX 5.3 platform) into Gambit v2 then solve using Fluent package (version 6.0.12 in window platform). I have these following tools, fluent 6.0.12 window version, Gambit 2 window version, start-CD 3.10 IRIX version and MSC.Patran 2001.
What I attempt to do are: 1)read the Star-CD v2.2 files using Star-CD v3.10 package with proStar 2)try to convert geometry into readable format in Gambit 3)regenerate the mesh in Gambit and save in Fluent format. 4)Solve with Fluent.
What the problem I have faced is Star-CD v2.2 files have no file extension and Star-CD v3.10 files have extension. Do you think my method is acceptable? Can you show me how to read old star-CD v2.2 files in star-CD v3.10?
Thanks.
Old   August 11, 2003, 13:42
Default Re: Read Star-CD V2.2 in V3.10
Leo
try renaming file 16 with a .mdl extension. For example, rename star16 to star.mdl and then try opening it in prostar.
Old   August 13, 2003, 10:57
cjtune
You can try using the CDSAVE command. It saves your model data as commands in a text-file format. You should get the following files: xyz.inp, xyz.vrt, xyz.cel, xyz.bnd. Just read in the .inp file in the newer ProSTAR.
Can Star-CD read 1D element mohr Siemens 1 September 26, 2005 12:31
How to read .cel .vrt of STAR-CD Raja Siemens 1 January 19, 2004 05:08
How to read .cel .vrt of STAR-CD Raja Siemens 0 January 16, 2004 04:11
