identify Cell face
Old   August 26, 2003, 10:37
Default identify Cell face
Sunlight007
Hello, i am a beginner: the mesh is a tube: how to get the cell faces on the outer diameter? I want to attach shell or baffle only to these faces? Face Number: how to get it? I want to color for e.g. face 1 with color 1 and so on. Thank you
Old   August 29, 2003, 12:50
Default Re: identify Cell face
m-hack
Hey!
You have a lot boolean possibilities to select all kind of cell arrangements in Star. Try some of the basic options with your mesh:
CSET, NEWS
CSET, ADD
CSET, SUBSET
CSET, UNSELECT
CSET, *,ZONE is useful if you want to select some cells out of the displayed ones.
Numbers:
Menu > Plot > number > Cell
Greetings.
Old   August 29, 2003, 13:56
Sunlight007
Hello, i know the cset commands i want to know how to get the cell faces for example 6 faces of a hexagonal cell. Greetings
Old   August 30, 2003, 05:30
Brian
There is a command, PLFACE, that will allow you to display the cell face numbers, by colouring them.
UDF: Given coordinates, How to identify the cell? Zhang Fluent UDF and Scheme Programming 26 August 15, 2022 05:54
[Technical] How to identify cell neighbours booz OpenFOAM Meshing & Mesh Conversion 59 November 20, 2017 00:40
How to identify boundary cell and internal cell dbxmcf OpenFOAM Running, Solving & CFD 2 November 6, 2016 09:11
cell velocity U and its cell face area Chinayu Siemens 0 May 6, 2006 22:44
DPM velocity at cell face Szabolcs Varga FLUENT 1 September 16, 2004 07:30
